Windows Services and NVIDIA monitoring
tpolson01
Post by tpolson01 » Sun Apr 07, 2019 1:24 am
Is there any documentation on implementing the new 2.3.1 features?
BTW, thanks for adding these.
Re: Windows Services and NVIDIA monitoring
Post by timurhai » Sun Apr 07, 2019 3:21 pm
NVIDIA: http://cgru.info/afanasy/render#custom_resources
Services: There is the lack of documentation on this topic for now.
Scripts to manipulate windows service(s) are here:
https://github.com/CGRU/cgru/tree/maste ... sy/service
You can watch them, may be rewrite (create own) to customize.
To launch such script you can use a cmd.exe by administrator.
NatRUS
Post by NatRUS » Fri Jul 12, 2019 9:46 am
Hi! I just new user. I tried use services for server and render, BUT render's service didn't run and gives an error message:
C:\cgru.2.3.1>if defined AF_RENDER_CMD (""  )  else ("C:\cgru.2.3.1\afanasy\bin\afrender.exe"  )
Fatal Python error: Py_Initialize: unable to load the file system codec
ModuleNotFoundError: No module named 'encodings'
Current thread 0x00001998 (most recent call first):
SERVICE: Fri 12 Jul 12:21.41: render process finished.
I tried copy python's encodings package C:\cgru.2.3.1\afanasy\bin\, but it get me another error with different packages. I copy all libs from C:\cgru.2.3.1\python\Lib and it was running. But after add task, service stops and get me this error:
 ERROR   RenderHost::stopTask: No such task: TP: j1 b0 t0 (now running 0 tasks).
and in job's Output log I get:
ERROR: Can't get file:
c:/temp/afanasy\jobs\0\2.afansy.aep\tasks\0.0\output\1.txt
No such file or directory
What do I do wrong?
Thank's
Post by timurhai » Fri Jul 12, 2019 10:58 am
I did not got how your question is connected to Windows Services and NVIDIA monitoring.
(viewtopic.php?f=11&t=3228)
Or you want to say, that everything worked fine, until you start afrender via service and turned on NVIDIA monitoring?
NatRUS
Post by NatRUS » Fri Jul 12, 2019 11:22 am
I run Windows Service from folder "C:\cgru.2.3.1\afanasy\service". But Server's service work fine, and Render's service - not working.
Post by timurhai » Fri Jul 12, 2019 11:37 am
Does it work fine w/o service? If you run afrender directly from keeper or by double clicking cmd from explorer or from a console?
NatRUS
Post by NatRUS » Fri Jul 12, 2019 11:45 am
If I run from keeper, or render.cmd from "C:\cgru.2.3.1\start\AFANASY", then Render Registered. BUT (I tired use for After Effects), I get error
Error Hosts:1/1:Avoiding
. But still frames rendered, and I see them in Render folder. But render next task didn't continue (img below). In Output log I get:
PROGRESS: 12.07.2019 14:37:42: Finished composition Comp 1.
PROGRESS: Total Time Elapsed: 0 Seconds
. I don't know, why It's getting error after render complete.
Post by timurhai » Fri Jul 12, 2019 12:03 pm
We are jumping for one theme to other.
Can you repost this in AE folder: viewforum.php?f=30
