afrender service
Posted: Fri Feb 24, 2017 7:47 pm
Hey folks,
we recently upgraded from Fedora22 and CGRU 2.0.8 to Fedora24 with CGRU 2.2.0.
Aside from some minor issues, one problem we have has to do with the afrender service: It no longer starts at startup of the OS.
Checking the status reveals the following:
I printed the PATH variable right before line 107 and /usr/bin/ is in it. If I replace the "su" by /bin/su or /usr/bin/su I get the "permission denied" message.
I am not experienced enough with linux, so I dont really know where to go from here. The problem is the same on freshly installed Fedora25 with CGRU 2.2.0.
Can anyone help me with this?
Thanks!
? afrender.service - LSB: Afanasy afrender daemon
Loaded: loaded (/etc/rc.d/init.d/afrender; generated; vendor preset: disabled)
Active: failed (Result: exit-code) since Fr 2017-02-24 18:12:19 CET; 5min ago
Docs: man:systemd-sysv-generator(8)
Process: 1299 ExecStart=/etc/rc.d/init.d/afrender start (code=exited, status=1/FAILURE)
Feb 24 18:12:19 ra-101-15 systemd[1]: Starting LSB: Afanasy afrender daemon...
Feb 24 18:12:19 ra-101-15 afrender[1299]: uid=1001(render) gid=1001(render) groups=1001(render)
Feb 24 18:12:19 ra-101-15 afrender[1299]: Starting afrender...
[size=150]Feb 24 18:12:19 ra-101-15 afrender[1299]: /etc/rc.d/init.d/afrender: line 107: su: command not found[/size]
Feb 24 18:12:19 ra-101-15 afrender[1299]: Can't execute process.
Feb 24 18:12:19 ra-101-15 systemd[1]: afrender.service: Control process exited, code=exited status=1
Feb 24 18:12:19 ra-101-15 systemd[1]: Failed to start LSB: Afanasy afrender daemon.
Feb 24 18:12:19 ra-101-15 systemd[1]: afrender.service: Unit entered failed state.
Feb 24 18:12:19 ra-101-15 systemd[1]: afrender.service: Failed with result 'exit-code'.
Thanks!
