afrender service
jjungfels
afrender service
Post by jjungfels »
Hey folks,
we recently upgraded from Fedora22 and CGRU 2.0.8 to Fedora24 with CGRU 2.2.0.
Aside from some minor issues, one problem we have has to do with the afrender service: It no longer starts at startup of the OS.
Checking the status reveals the following:
? afrender.service - LSB: Afanasy afrender daemon
   Loaded: loaded (/etc/rc.d/init.d/afrender; generated; vendor preset: disabled)
   Active: failed (Result: exit-code) since Fr 2017-02-24 18:12:19 CET; 5min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 1299 ExecStart=/etc/rc.d/init.d/afrender start (code=exited, status=1/FAILURE)
Feb 24 18:12:19 ra-101-15 systemd[1]: Starting LSB: Afanasy afrender daemon...
Feb 24 18:12:19 ra-101-15 afrender[1299]: uid=1001(render) gid=1001(render) groups=1001(render)
Feb 24 18:12:19 ra-101-15 afrender[1299]: Starting afrender...
[size=150]Feb 24 18:12:19 ra-101-15 afrender[1299]: /etc/rc.d/init.d/afrender: line 107: su: command not found[/size]
Feb 24 18:12:19 ra-101-15 afrender[1299]: Can't execute process.
Feb 24 18:12:19 ra-101-15 systemd[1]: afrender.service: Control process exited, code=exited status=1
Feb 24 18:12:19 ra-101-15 systemd[1]: Failed to start LSB: Afanasy afrender daemon.
Feb 24 18:12:19 ra-101-15 systemd[1]: afrender.service: Unit entered failed state.
Feb 24 18:12:19 ra-101-15 systemd[1]: afrender.service: Failed with result 'exit-code'.
I printed the PATH variable right before line 107 and /usr/bin/ is in it. If I replace the "su" by /bin/su or /usr/bin/su I get the "permission denied" message.
I am not experienced enough with linux, so I dont really know where to go from here. The problem is the same on freshly installed Fedora25 with CGRU 2.2.0.
Can anyone help me with this?
Thanks!
CGRU 2.2.0 - Fedora24 - Maya 2017
Jakob Jungfels
priel71
Re: afrender service
Post by priel71 »
Hi Jakob, I find that writing a small oneshot service script was easiest... Then I just keep the afserver and afrender in the /usr/local/bin folder. Here's an example service script (/etc/systemd/system/afserver.service):
[Unit]
Description=AFServer
After=network.target
[Service]
Type=oneshot
ExecStart=/usr/local/bin/afserver start
RemainAfterExit=true
ExecStop=/usr/local/bin/afserver stop
ExecReload=/usr/local/bin/afserver restart
StandardOutput=journal
[Install]
WantedBy=multi-user.target
Peter.
Edit... just saw you were referring to the afrender service, but I do the same there, just start the afrender script instead of the afserver...
jjungfels
Post by jjungfels »
Thank you Peter. I will try your suggestion.
Jakob Jungfels
