I have installed CGRU on my Fedora 27 Workstation.
I would start the Keeper but I became this error. (screen is in the attachments)
It's possible to run the keeper in the new GNOME 3.26 environment?
Thank you very much!
Linux
Keeper System tray error (Fedora 27)
Re: Keeper System tray error (Fedora 27)
I do not see any attachments.
May be unapproved posts can't have attachments.
You can try to run keeper in a terminal:
This way more error info can be printed.
Also Gnome3 is the worst manager. Gnome2 was very good, so now gnome users makes Mate to continue it.
No most linux distros has various other managers.
cd /opt/cgru
./start.sh
My mistake. The attachment should be now there.
- nosystemtray_error.png (90.51 KiB) Viewed 7974 times
I can`t say anything before i try Fedora27 myself. But i do not have it by hand.
I just raise various virtual-box machines periodically to test releases on a modern distributions.
You case can cause new Gnome3 "system tray icons" approach and a new Python (PyQt/PySide) issue.
Try to install XFCE window manager - it is a render client, why it should have a modern windows themes?
Try to install change (uninstall / install) between PyQt5 - PyQt4 - PySide - PySide2, or what ever your distribution has, may be it will work somewhere.
I is very strange to have render-client on such distribution. Fedora is used to test something, not to work. If you want a stable and free RedHat based distribution - use CentOS, it is much more similar to RedHat (has the same sources) than Fedora.
Thank you very much for your help.
I will try it on CentOS 7.
