New web Gui
Web browser GUI uses JSON over HTTP protocol.
Draco
New web Gui
Post by Draco » Sun Jul 28, 2019 8:05 pm
Hi All,
We have developed a new web interface for cgru
https://github.com/Arubinu/Draco-CGRU
We welcome your feedback and your new ideas
Best,
Anthony
Re: New web Gui
Post by timurhai » Mon Jul 29, 2019 9:33 am
Great!
Have you tried this config variable?
https://github.com/CGRU/cgru/blob/maste ... t.json#L13
- to not replace original files.
Later better add an ability to afserver to serve several (any number) of web GUIs at the same time.
Sorry, but for a next several months i will be very busy, and will not have enough time for the project to tests/reviews.
I also working with a new feature - render pools. It will take some time too.
Draco
Re: New web Gui
Post by Draco » Tue Jul 30, 2019 11:15 am
Thank you for the comment.
Indeed, it would be very convenient to be able to change the theme, and looking at the side of "af_http_serve_dir", I understood that it would change the starting point of the web server.
This is not practical since our interface relies on the scripts and files present from the root of CGRU.
I will suggest adding a variable such as "af_http_serve_index", which would replace "AFGENERAL :: HTML_BROWSER" which is always "/afanasy/browser/index.html".
In this case we could stay on the same basis, keep the original web interface, and leave the possibility to change quickly (involving a restart of afserver)!
Thank you for this tool.
Re: New web Gui
Post by timurhai » Tue Jul 30, 2019 11:28 am
Even better, if each user can choose what GUI to use, so one use can use one GUI and other the other at the same time.
And a config setting for afserver what is the default one.
Mikas
Re: New web Gui
Post by Mikas » Tue Oct 15, 2019 12:23 pm
Thanks a lot for this UI. It's so much more convenient than the default one. And the right click menu's are godsend. Very cool!
