newbe questions
Customize rules.
ahmad
newbe questions
Post by ahmad » Thu Sep 21, 2017 10:07 am
hi,
sorry for bad english.
I'm newbe. i have some questions.
1. whether the server affanasy need to connect database server. for what and how to properly configure.
2. I use Blender. I installed the manual plug-in and configure the root cgru folder in user preferens but I get this error when submitting job
  File "C: \ Users \ far_i \ Downloads \ Compressed \ cgru.2.2.2.windows \ lib \ python \ cgruconfig.py", line 80, in __init__
    raise KeyError ('CGRU_LOCATION')
KeyError: 'CGRU_LOCATION'
During handling of the above exception, another exception occurred:
  File "C: \ Users \ far_i \ Google Drive \ scrip Blender \ Blender \ 2.78 \ scripts \ addons \ cgru_tools \ operators.py", line 62, in execute
    import af
  File "C: \ Users \ far_i \ Downloads \ Compressed \ cgru.2.2.2.windows \ afanasy \ python \ af.py", line 10, in <module>
    import cgruconfig
  File "C: \ Users \ far_i \ Downloads \ Compressed \ cgru.2.2.2.windows \ lib \ python \ cgruconfig.py", line 248, in <module>
    Config ()
  File "C: \ Users \ far_i \ Downloads \ Compressed \ cgru.2.2.2.windows \ lib \ python \ cgruconfig.py", line 82, in __init__
    raise KeyError ('Environment variable CGRU_LOCATION not set.')
KeyError: 'Environment variable CGRU_LOCATION not set.'
note: run Blender manual not from keeper
Re: newbe questions
Post by timurhai » Thu Sep 21, 2017 12:07 pm
CGRU needed some environment to work:
http://cgru.info/installation#config_environment
If you run Blender from keeper, it will set all needed environment.
If you run Blender in your own way, you should setup required environment in your own way.
ahmad
Re: newbe questions
Post by ahmad » Thu Sep 21, 2017 2:35 pm
thanks for reply. i got it. solved problem.
Re: newbe questions
Post by timurhai » Fri Sep 22, 2017 9:04 am
Sorry, just noticed your first question:
This is to gather SQL statistics only.
Afanasy works only with PostgreSQL, configuration guide is here http://cgru.info/afanasy/server#statistics
ahmad
Re: newbe questions
Post by ahmad » Fri Sep 22, 2017 8:55 pm
ok, i think for user authentication.
thanks for the answer.
