General
skyline
General
Post by skyline »
After rendering ,I can't find results in my local machine .And when I using 3dsmax,I have to copy scene files to render machine.If not, the job can't be executed。The error log is reading scene file **.max failed。Why?
Thank you
Re: General
You should use network paths (map network drives) everywhere (or relative paths, relave to the project or to the process working directory).
As the result, any path (to the scene ot to the texture in the scene) must be the same on any machine.
So you should keep nothing on a local machines, keep all in the network.
skyline
Re: General
Post by skyline »
can we run two rendering tasks at the same time in a machine?Run two threads for render tasks in a machine?If we can,how to set to run two or more tasks concurrently in a machine.
Thank you
Re: General
If render has 2000 capacity, it can take 2 tasks with 1000 capacity, or 1x1000 + 2x500, or 4x500 and so on.
skyline
General
Post by skyline »
I don't find any exist web server like apache or nginx. Does cgru use any web server? How does it connect to browser?Or where are the code?
Re: General
I did not got what are you asking. And how this is connected to 3D Max (this forum topic).
If you are talking about Afanasy Web GUI, you should ask here:
viewforum.php?f=17
Also Rules project tracker and Afanasy statistics database browsing has a Web GUI.
