3DSMax-Vray no thumbnails
skyline
Post by skyline » Fri Oct 19, 2018 4:48 am
hi,
when I using 3dsmax with vray to render, I can't get task's thumbnails in watch page. How to set to show thumbnails int watcher page
when job monitoring
thank you
Re: 3DSMax-Vray no thumbnails
Post by timurhai » Fri Oct 19, 2018 9:27 am
Thumbnails are generated by afrender after (or during) task calculation.
Afrender should know a path to image file(s) to generate thumbnails.
This path can be given to job on a submission stage, and than, afserver will send it to render with a task.
Or afrender can parse image path from a task process output.
If there is no thumbnail, no of those 2 conditions happen.
Afrender can't generate a thumbnail of an image that it does know where to get.
The best way to is provide image path and on a job submission and learn parser to find it.
skyline
vray log
Post by skyline » Mon Oct 22, 2018 3:04 am
hi,
when I using vray for 3dsmax to render, can I get vray's render log? how to get it ?
Post by timurhai » Mon Oct 22, 2018 9:18 am
Can you double click task from afwatch.
Does it has "Files"? Files paths are correct?
