3dsmax 2018 ignore errors.
Posted: Thu Oct 05, 2017 7:02 pm
by lcenzoredl
The problem is that 3ds max 2018 don't mark task as Error even it has errors.
If we run 2 identical jobs in two versions of max - 2017 and 2018, the tasks in 2017 will be marked in usual way with Error status, but in 2018 it would be marked as Done.
I watch the log, and don't find the differences which can affect for that.
They not identical but both have strings like "error".
Here it looks like in AfWAtch:
Same JOB, left - 2018, right -2017
And logs from first tasks:
2017:
2018:
How Afanasy mark errors? If it searches words like "error" or something like that, why it ignores errors in max2018?
Re: 3dsmax 2018 ignore errors.
Posted: Tue Oct 10, 2017 8:24 pm
by lcenzoredl
So, 3dsmax 2018 output Exit Code = 0, even if some errors exists.
And I don't know how to change it.
Posted: Sat Oct 14, 2017 8:55 am
Afanasy uses exit code and task process output (stdout and stderr) parsing for errors.
If your command exits with a non zero exit status, task will be marked as error.
If parser will find some special keywords task will be marked as error.
Goog/Bad exit status code can be customized for service:
https://github.com/CGRU/cgru/blob/maste ... ce.py#L237
Parser is a Python class that can be customized.
You should dig your command (application) deeper and say what may be wrong in Afanasy code for a new Max version. I do no have any Max, or even MS Windows.
I will not even read Russian language on this site.
Use this forum to speak Russian: http://grafans.ru/
