Houdini tiled rendering problems with Image Planes
IPAnimation
Post by IPAnimation » Fri Sep 22, 2017 11:55 am
We are having issues with tiled renders not writing out the images planes that are present in scene. Doing a local render or non-tiled submission with Afanasy works as expected.
Looking at the tile renders generatedby the job before the stitch, it appears that whilst there is a separate .exrfile written out for every tile named "filename.exr.tile_1.exr" for example for tile #1, this contains no image plane information. We also have a file namedsimply "filename.exr" which does have embedded image planes but seems to be being written to by each node that is rendering a tile, simultaneously and is always unreadable.
Is this correct behaviour and does Afanasy actually support tiled rendering with image planes in Houdini? I would have thought that each separate tile .exr would contain all of the required image planes for the stitched image.
If you can shed any light on what we may be doing incorrectly that would be appreciated.
thanks
Tom
Re: Houdini tiled rendering problems with Image Planes
Post by timurhai » Fri Sep 22, 2017 12:55 pm
We use Afanasy-Houdini tile render periodically.
Several image planes (we write all planes in one exr) works fine too.
So we should look at your problem more detailed.
How do you submit job?
What options Afanasy ROP node has?
What job was generated?
What are tasks outputs?
IPAnimation
Post by IPAnimation » Fri Sep 22, 2017 12:55 pm
I forgot to say, this is using Afanasy 2.2.2 and Houdini 16.0.557
thanks
IPAnimation
Post by IPAnimation » Fri Sep 22, 2017 1:04 pm
The following are all enabled on Afanasy ROP.
Enable Seperate Render
Run ROP
Read Paramaters from ROP
Delete EOP files on Deletion
Use temp Images Folder
Tile Ren
The job is submitted from within Houdini, using the submit tab on the afanasy ROP.
There are three blocks generated in the job,
1: IFD generation (we only have one machine with Houdini Engine for IFD generation)
2: tile renders
3: stitch
The ifd is generated, the tiles render and final is stitched, so all appears to work but the final stitched image has no image planes embedded. Looking at the tiles as they render, they also have no image planes. During the tile rendering there is an extra file initially generated "filename.exr" that does have image planes (can pull this into Nuke but is always blank but does have the image planes listed). I'm assuming that internally mantra does not know to render the image planes to the file with the tiled .exr suffix? Not sure how to go about fixing that....assuming it's embedded within the afanasy mantra scripts?
IPAnimation
Post by IPAnimation » Sat Sep 23, 2017 12:49 pm
Any ideas anyone? I'm not overly technical so struggling to pinpoint the cause or come up with a solution.
thanks.
Post by timurhai » Sun Sep 24, 2017 11:24 am
I can just say that it works for me. Houdini is 15.5.
I never managed to launch Houdini 16 yet.
May be OpenEXR version changed, may be anything else.
You can try "native" Houdini tile render.
( to automate it, you can use wedge )
After render, you can stitch tiles in compositing soft.
