ImageMagick
priel71
ImageMagick
Post by priel71 » Wed May 20, 2020 4:04 am
Hi, on updated cento 7 boxes, we are getting flipped images when doing dailies. I have looked at the packages, and I think the issue is with ImageMagick.
The version that worked as expected, was the older ImageMagick 6.7.x
These new boxes are running ImageMagick 6.9.10-68 Q16 and all of them are creating dailies which are flipped upside down.
Has anyone else had this problem?
Peter.
priel71
Re: ImageMagick
Post by priel71 » Wed May 20, 2020 4:48 am
After some digging, it seems as if Red Hat and by default CentOS has dropped ImageMagick in the future and instead packages their distro with GraphicsMagick. Would it be possible to break out the commands into the config files, so we can set it to either use the regular "convert", or replace it with "gm convert" which is now how we have to access it on Centos distros?
priel71
Re: ImageMagick
Post by priel71 » Wed May 20, 2020 4:54 am
Probably not the best idea... seems some of the command line arguments in gm convert are different from the regular ImageMagick arguments. Like -identify for instance.
Re: ImageMagick
Post by timurhai » Wed May 20, 2020 1:37 pm
On Ubuntu 18.04 (that we are wirking on) we have:
$ convert --version
Version: ImageMagick 6.9.7-4 Q16 x86_64 20170114 http://www.imagemagick.org
Copyright: © 1999-2017 ImageMagick Studio LLC
License: http://www.imagemagick.org/script/license.php
Features: Cipher DPC Modules OpenMP
Delegates (built-in): bzlib djvu fftw fontconfig freetype jbig jng jpeg lcms lqr ltdl lzma openexr pangocairo png tiff wmf x xml zlib
And everything works fine.
priel71
Re: ImageMagick
Post by priel71 » Wed May 20, 2020 1:39 pm
Yeah strange. It's the same on every box I update.
Anyway, downgraded to a older ImageMagick and it's working fine.
Peter.
