Not Solving in parallel mode
Posted: Fri Mar 24, 2017 5:51 pm
If I run Afanasy with this config:
And I set the submitting user to "Parallel" mode and submit 3 500 frame jobs across 12 renders all with the same Priority. The Solver will not balance the jobs across the all renders. IE. First job should be on 4 renders, Second job another four renders, Third on the last four renders.
Is there something I'm missing?
Scott
"":"Solving:",
"af_solving_use_capacity":true,
"":"Calculate need using running tasks total capacity.",
"":"If not, use only running tasks number",
"af_solving_use_user_priority":false,
"":"Whether task solving takes user priority into account or not. If set on,",
"":"Jobs are sorted by user's priority first, then by job priority within a user.",
"":"If not, only job proirities are used.",
"af_solving_simpler":true,
"":"Use a simplified solving algorithm. No notion of 'need' is used: jobs are",
"":"sorted by priority first, and creation date then (older first).",
Scott
