Can't set af_servername without GUI
victor
Post by victor » Wed May 24, 2017 8:42 am
Our renders machines (agents) setup automatically and run as a windows services.
Thus we need to set 'af_servername' using a script (without GUI).
For that purpose we use C:\Users\Administrator\AppData\Roaming\cgru\config.json.
In this file our script sets af_servername = "10.163.2.222"
In GUI setting servername is 10.163.2.20
The result:
The render cannot connect to the server and only when we manually change the server in GUI to 10.163.2.222 it connects successfully.
running _afcmd.cmd prints the following strange lines:
Parsing config file ‘C:\Users\Administrator\AppData\Roaming\cgru/config.json’:
af_servername = ‘10.163.2.20’
As I mentioned in this file af_servername = "10.163.2.222"
Please help.
Victor
Re: Can't set af_servername without GUI
Post by timurhai » Wed May 24, 2017 8:52 am
Setting af_servername from GUI is not needed at all. It was made just for testing.
This is our cgru/config.json file for MS Windows platform:
{"cgru_config":{
	"include":["T:/config.json"]
It just includes other config from a shared place.
"AppData\Roaming\cgru" just needed to store user specific settings, like afwatch color there, it should be used for a farm setup.
victor
Post by victor » Wed May 24, 2017 10:42 am
Sorry, I still dont understand what should I do to make it work properly.
What file does define the actual config?
Where should it be located?
Post by timurhai » Wed May 24, 2017 11:02 am
victor
Post by victor » Mon May 29, 2017 8:43 am
Ok, we resolved our issue.
The problem was the way we run it in windows:
It runs as a windows service.
When the service runs under Admin user it takes the config defined by the GUI.
We changed the service to run as a System user and only then it takes the config from the files as defined in documentation.
