frame checking
Posted: Tue Jun 06, 2017 3:10 pm
I tried using framechecking in the python service. It seems that on any numeric task only the first frame is checked. I think it would be best to do it on all frames.
The problem is, that taskinfo["files"] in the python service class contains always only the first frame of a numeric task.
As I see it, there are two ways to solve this problem:
a) make taskinfo["files"] contain all frames in this task, not only the first one.
This needed to be added around here: https://github.com/CGRU/cgru/blob/maste ... .cpp#L1166
b) get the block pattern and the Task's start and endframe as a parameter on taskinfo
Am I missing something here? What do you think about this?
