Node shutdown after task complete
Des
Post by Des »
Hi Tim!
Great afanasy!
Question:
I want to be able to shutdown node after task completes, not job but task. What should i configure for it work?
Re: Node shutdown after task complete
There is no such feature "out-of-the-box".
Afanasy can't automatically shut down render node after a job or a task completes.
Des
Post by Des »
Ok, i understand.
What should i look for, where could i inject a shell script in the task submitting with python?
I read there is cmd task or so, could i put there the execution of node shutdown? does it execute after the task is done (frame finished)?
Thanks!
It depends on your needs.
You want to create some job, that will run some command on each machine only once, than node should be shutdown?
You want to ask render some node (from GUI or API) to shutdown after the current running task will be finished?
Des
Post by Des »
I want to shutdown the node after it finishes its task. So Task done > shutdown.
You can change task command to:
do_some_work && shutdown -P
Des
Post by Des »
ok, so basicly in python i will just add at the end of the cmd the shutdown cmd and it will pass.
clever. i never thoutght about that. +100 for you mister T. :) thanks alot for the tip
edit:
ive already setup the render user as able to execeute shutdown, so good good tip!
