Starter return JSON loads error
F2B
Post by F2B » Thu Jan 11, 2018 4:34 pm
affter i click the "Start" button in starter, it returns:
afnetwork.py: Received data:
"id":58,
"serial":74
}A
JSON loads error:
Extra data: line 4 column 2 - line 4 column 3 (char 24 - 25)
null
The job successfully sent.
This is the same error for every job i submit. I see JSON job structure but what line and column refer to???
Re: Starter return JSON loads error
Post by timurhai » Thu Jan 11, 2018 5:24 pm
This is an extra "A" character at the end of JSON data just after the last "}".
It is a bug appeared when server switched to non-blocking IO.
What OS afserver is running? Have you turned on linux epoll facility?
For now, if you need correct JSON you can just cat off everythin after the last "}", when JSON object finished.
F2B
Post by F2B » Fri Jan 12, 2018 9:34 am
Server runs on Windows.
What python file should i modify to clean that?
Post by timurhai » Fri Jan 12, 2018 10:04 am
bazarus
Post by bazarus » Mon Jan 15, 2018 10:06 am
Same error appears after sending job in houdini console.
"id":5599,
"serial":9930
}AAA
JSON loads error:
Extra data: line 4 column 2 - line 4 column 5 (char 28 - 31)
"id":5604,
"serial":9931
}AAAAAAAAAAAAAAAAAA
JSON loads error:
Extra data: line 4 column 2 - line 4 column 20 (char 28 - 46)
Can you explain a bit more how to solve problem?
Post by timurhai » Mon Jan 15, 2018 3:05 pm
You need a new job ID or Serial?
If so, just cut of AAA from the end.
If not - is it a problem?
Post by timurhai » Wed Feb 07, 2018 10:28 am
You can look here how this problem can be solved:
https://github.com/CGRU/cgru/commit/d16 ... 3b1f63c31c
You can get that file from master now, or it will be available in the next releases.
