Vray Parser update to create thumbnails
seven11
Post by seven11 »
We use this all the time for creating the thumbnails for Vray 3.40 renders.
Didn't know how to get it to you.
-Scott
afanasy/python/parsers/vray.py
from parsers import parser
import re
re_frame = re.compile(
	r'SCEN.*(progr: begin scene preprocessing for frame )([0-9]+)'
re_number = re.compile(r'[0-9]+')
re_percent = re.compile(
	r'Rendering image...:([ ]{,})([0-9]{1,2}.*)(%[ ]{,}).*'
IMAGE = r'Successfully written image file '
class vray(parser.parser):
	"""VRay Standalone
	def __init__(self):
		parser.parser.__init__(self)
		self.buffer = ""
		self.numinseq = 0
	def do(self, data, mode):
		"""Missing DocString
		:param data:
		:param mode:
		:return:
		# self.buffer += data
		# needcalc = False
		# frame = False
		if len(data) < 1:
			return
		lines = data.split('\n')
		for line in lines:
			pattern = re.compile(IMAGE)
			res = pattern.search(line)
			if res != None:
				quotes = re.split("\"", line)
				if quotes[1] != "":
					self.appendFile(quotes[1].strip())
		match = re_percent.findall(data)
		if len(match):
			percentframe = float(match[-1][1])
			self.percent = int(percentframe)
Re: Vray Parser update to create thumbnails
It will be useful to create a pull request on GutHub for such issues.
https://github.com/CGRU/cgru
seven11
Post by seven11 »
Will do.
Scott
Strob
Post by Strob »
How does it work? Is it for seeing the thumbnails in the tasks window?
like this?:
It is just work by default and this is all, no special GUI setup needed.
Of course there should be thumbnails.
So afrender should know about images to generate thumbnails.
There are 2 way for it, both can be used together:
- Submission script set "files" parameter to a job block.
- Python parser class can parse out a correct image path.
Strob
Post by Strob »
Ok you mean in my submission script I have to add a "files" parameter that tells what the path of the image out is?
And does it work only with jpg? I see only jpg in the example. I render only EXR.
Afrender make thumbnails with an ImageMagick convert utility:
https://www.imagemagick.org/script/convert.php
On Windows it does not understands EXR 'out-of-the-box'.
You should find out does your convert.exe understands exr files, and what to do if it does not.
You our solve this problem (it is solveable) i can write some info about it for others.
Or we can put "correct" convert.exe to the CGRU windows archive.
Strob
Post by Strob »
Ok I will try to play with this script to understand it.
