Task - Browse files/Preview
Afanasy Watch Qt GUI.
igorChopenko
Post by igorChopenko »
Hello again Timur.
I've used afanasy on windows 10, and noticed that task\block options "Browse Files" always sends explorer window to %USERPROFILE%\Documents, so my question is how to fix or customize that option.
second question, i trying to use RVplayer as my preview app, i've added RV option to %CGRU_LOCATION%\config.json,
but it works only on task level, so i can open single file instead of whole sequence,
when i use preview option on block level i've got error message: No files matched "someCorrectPath/test.@####@.exr (0) "
Can u give me advice or point to right direction?
Re: Task - Browse files/Preview
To execute correct command to view files, your jobs (blocks, tasks) should have a valid files parameter.
It can be set on a job creation or files can be parsed in a Python parser class.
All block tasks sequence preview is not working now, i see.
It is a bug that should be fixed by developers ( files pattern should be replaced by a real filenames ).
elecstorm
Post by elecstorm »
Browse files and "Folder" job's menu commands still not working on windows 10?
Can the user override these commands?
elecstorm
Post by elecstorm »
elecstorm wrote: Thu Oct 05, 2017 4:01 pm Hi!
We found "Open folder" command in Keeper - Configure - Set Open Folder, but it does not affect anything.
I changed it from explorer "@PATH@" to explorer "C:\", but it still opening home folder.
What is block/task "files" parameter?
Is it points to correct rendered files?
Can you send me task info? (you can get it from afwatch on a task double-click)
elecstorm
Post by elecstorm »
timurhai wrote: Sat Oct 14, 2017 9:05 am Hi.
frame 58
hbatch_mantra[hbatch_mantra]:1000 frames(58,58,1):
Command:
hrender_af -s 58 -e 58 --by 1 -t "_current_" "//deadline/workstation_02/1 _project/11-00/HOUDINI/V11_ANONS_IN_part2_v005.hip_V11_ANONS_IN_part2_v005.V11_ANONS_IN-part2_sun.1013-205555-746.hip" "/out/V11_ANONS_IN-part2_sun"
Working Directory:
C:\Python34
Files:
//deadline/workstation_02/1 _project/11-00/HOUDINI/RENDER/ANONS/PART2/V11_ANONS_IN-part2_sun_00058.exr
//deadline/workstation_02/1 _project/11-00/HOUDINI/RENDER/ANONS/PART2/V11_ANONS_IN-part2_sun_00058.exr is coorect Files, but it is Linux-like path.
elecstorm
Post by elecstorm »
We still have problems with Browse files - it doesn't work.
I created test scene with local paths, rendered it on local machine: browse files opens the home folder.
Task's log:
frame 1-5
hbatch[hbatch_redshift]:100 frames(1,5,5):
Command:
hrender_af -s 1 -e 5 --by 1 -t "_current_" "P:/projects/CONCEPT/concept_electric_004.hip_concept_electric_004.afanasy1.1102-120855-401.hip" "/out/elecstric_shur_v001"
Working Directory:
C:\Python34
Files:
F:/render/elecstric_shur_v001/elecstric_shur_v001.0001.exr
elecstorm
Post by elecstorm »
I changed also
"open_folder_cmd":"explorer \"@PATH@\""
to
"open_folder_cmd":"explorer c:"
in CGRU Config to debug this command: it doesn't affect to Keeper's defualt Open folder command.
May be path slashes direction plays affects.
Try to check "files" with windows ("\") type slashes.
elecstorm
Post by elecstorm »
timurhai wrote: Thu Nov 02, 2017 6:33 pm May be path slashes direction plays affects.
Ok, I changed both setFiles functions in af.py:
From
self.data["files"].append(afile)
P:/projects/R1/
To:
self.data["files"].append(afile.replace("/", "\\"))
P:\projects\R1\
And "Browse Files..." works fine now. But the solution is not right, right?
Where can I find a place in a source code, where "Browse Files" evaluates? "open_folder_cmd":"explorer c:" to debug this command did not affect anything, or it is another command?
