Can't read the archive file after submission.
Hi, with clarisse 3.6, some projects when submitted with "create render archive" checked, end up as unreadable files which do not render. It's not a huge issue, as you can de-check it and type in the *.project file instead, but anyway, thought I should mention it.
Re: Can't read the archive file after submission.
I am not a Clarisse user and does not have it by hand.
But if you are, you can perform some debug, to find out what is going wrong.
For example, you can say that: "since a xx.xx version to make a correct archive we should change command this way", or something more concrete, not just "it does not works".
If you find some bug and what should be changed, i can guide you how to do it.
CGRU 2.2.3 Ubuntu 14.04LTS (gcc4.8.4)
My apologies, I will try to dig into the issue and provide you with some more concrete information. I have tried to look at the archives the submission script creates, but since they appear to me, to be binary files, I'm afraid it's out of my depth. I will check and see if I can gather any information from the Clarisse software itself, perhaps there is some debug flag.
