Nuke error Unknown switch: -r
Collagene
Post by Collagene » Thu Dec 13, 2018 12:07 pm
Gday.
We are trying submit nuke scripts with centos7 and w10 Through render selected panel inside Nuke but we got this output error message :
Starting CGRU Nuke add-ons from: /opt/cgru/plugins/nuke Unknown switch: -r C:cgru.2.2.3pluginsnukerender.py : No such file or directory Exception IOError: (2, 'No such file or directory', 'C:cgru.2.2.3pluginsnukerender.py') in <module 'threading' from '/usr/local/Nuke11.2v4/lib/python2.7/threading.py'> ignored
we use this great dispatcher daily with maya scenes smoothly whit different OS by Afanasy Starter windows .
Here our config json config file
{"cgru_config":{
"":"This is a CGRU default config file",
"":"Describe your own configuration in 'config.json', it will be included last",
"":"To disable property you can just prefix it with '-'",
"include":["afanasy/config_default.json","config.json"],
"":"'OS_unix': Any UNIX (Linux, MacOSX) specific settings",
"":"'OS_windows': MS Windows specific settings",
"":"'OS_linux': Linix specific settings",
"":"'OS_macosx': MacOSX specific settings",
"":"Digest authentication realm",
"realm":"CGRU",
"":"To open location/shot in RULES:",
"-rules_url":"http://localhost/cgru/#/",
"":"By default it is disabled",
"projects_root":["/mnt/prj/","/projects/","/cgru/rules_root/"],
"nuke_filenamefilter":true,
"open_folder_cmd":"open \"@PATH@\"",
"previewcmds":[
"Nuke|nuke -v \"@ARG@\"",
"Mplay|mplay \"@ARG@\"",
"Mplay *|mplay `dirname \"@ARG@\"`/*",
"DJV|djv_view \"@ARG@\"",
"IMDisplay|display \"@ARG@\"",
"XTerm Folder|cd `dirname @ARG@` && xterm"
"annotations":[
"APPROVED",
"FAILED"
"docs_url":"http://cgru.info",
"forum_url":"http://forum.cgru.info",
"":"Configure SMTP server to send emails from",
"email_smtp_server":"localhost",
"":"You can keep 'localhost', but configure machines with RULES server",
"":" and Afanasy 'events' service to have such service running",
"":"This command provided with CGRU and uses utilities/emailsend.py Python script",
"email_send_cmd":"emailsend",
"email_sender_address_host":"cgru.info",
"keeper_port":50999,
"keeper_port_https":50443,
"timeformat":"%a %d %b %H:%M.%S",
"":"'strftime' function format http://www.cplusplus.com/reference/clib ... e/strftime",
"filenamesizemax":250,
"platforms":["linux","mac","windows"],
"OS_unix":{
"cmd_shell":"/bin/sh -c"
"OS_windows":{
"open_folder_cmd":"explorer \"@PATH@\"",
"cmd_shell":"cmd.exe /c",
"":"This is a paths map example (disabled)",
"":"Client:Server",
"pathsmap":[
["X:/","/mnt/nas/"],
"":"Client slashes direction plays no role, as it tries both slashes when searchs a path to replace.",
"":"But will replace with specified slashes, if unix slashes not forced (for Nuke, for example)."
"OS_linux":{
"open_folder_cmd":"nautilus \"@PATH@\"",
"pathsmap":[
["/mnt/nas/","X:/"],
"pswd_visor":"1832116180fdc61b64fd978401e462e9",
"pswd_god":"73bcaaa458bff0d27989ed331b68b64d",
Do you have any advice for fixing the Nuke issue.
Thank u in advance.
Band tm
Re: Nuke error Unknown switch: -r
Post by timurhai » Thu Dec 13, 2018 12:22 pm
You should keep in you config.json only modified parameters. This way is simple to detect/maintain changes.
When and where that message appears?
Just after "Render Selected..." menu item hit?
Just after "Ok" button pressed in "Render Selected" dialog?
This is an error task output?
Singe message contains and Linux and Windows paths, may be there is some paths mess?
This topic should be in "Nuke" section.
Collagene
Post by Collagene » Thu Dec 13, 2018 12:57 pm
Thank you for the quick reply.
this message appears in the listen job tab of the web monitor. There is no error after "Render Selected..." menu item hit, only during render.
The full message is :
frame 51[boxx4-pc.band]:
HOSTNAME=boxx4-pc.band
LM_LICENCS_FILE='/usr/local/Nuke11.2v4/nuke.lic'
NUKE = '/usr/local/Nuke11.2v4/Nuke11.2'
Nuke 11.2v4, 64 bit, built Oct 9 2018.
Copyright (c) 2018 The Foundry Visionmongers Ltd. All Rights Reserved.
CGRU filenameFilter added:
Unknown switch: -r
File "/usr/local/Nuke11.2v4/plugins/nuke/callbacks.py", line 421, in filenameFilter
s = f[0](filename,*f[1],**f[2])
File "/opt/cgru/plugins/nuke/scripts/cgru/pathmap.py", line 34, in pmFilenameFilter
filename = PMaps[key].toClient(filename)
UnboundLocalError: local variable 'key' referenced before assignment
thanks
Post by timurhai » Thu Dec 13, 2018 1:53 pm
This was some testing feature some time, i did not heard that somebody used it.
You are really need this feature?
This feature worked with previous Nuke or(and) CGRU versions?
Post by timurhai » Thu Dec 13, 2018 3:22 pm
Anyway, you can disable that feature anytime.
Remove this line from you config.json:
mateusz@autonomy.pl
Post by mateusz@autonomy.pl » Wed Mar 27, 2019 10:46 am
I have similiar problem with cgru 2.3.0,
rendering task on linux which come from windows gives error :
"(Starting CGRU Nuke add-ons from:
C:cgru-windowspluginsnukerender.py : Nie ma takiego pliku ani katalogu
Exception IOError: (2, 'Nie ma takiego pliku ani katalogu', 'C:cgru-windowspluginsnukerender.py') in ignored)"
But i dont have ""nuke_filenamefilter":true," in my config.json...
any advice?
Post by timurhai » Wed Mar 27, 2019 1:59 pm
Can you show task command on (for) Linux?
It seems that paths from windows to Linux not mapped.
mateusz@autonomy.pl
Post by mateusz@autonomy.pl » Wed Mar 27, 2019 2:42 pm
thats how command lookslike
"frame 1105939-1105948
nuke[nuke]:1000 frames(1105939,1105948,10):
Command:
nuke -i -t C:\cgru-windows\plugins\nuke\render.py -X Write1 -F1105939-1105948x1 -x "P:\P96_BNP-paribas-TOPVIEW\CG\COMP\NUKE\disabled_pakiet.nk.0327-151837-209.disabled_pakiet.nk-afanasy.nk""
also task submited on linux to windws error looks like
"Starting CGRU Nuke add-ons from:
/opt/cgru/plugins/nuke/render.py : No such file or directory
Exception IOError: (2, 'No such file or directory', '/opt/cgru/plugins/nuke/render.py') in <module 'threading' from 'C:\Program Files\Nuke11.1v1\lib\threading.py'> ignored"
Post by timurhai » Wed Mar 27, 2019 2:50 pm
This command can not be executed on Linux:
May be this is command for windows, not for Linux?
To get command for Linux, you can open afwatch on Linux and get task command there.
Have you configured your paths map to use mixed OS rendering?
http://cgru.info/afanasy/render#paths_map
mateusz@autonomy.pl
Post by mateusz@autonomy.pl » Wed Mar 27, 2019 2:58 pm
yes i have configured pathmap.
For blender it works fine, commands are converted to linux paths, but for nuke its not working at all. command look same on windows and linux machine...
this is config.json:"
{"cgru_config":{
"nuke_filenamefilter":false,
"af_servername":"192.168.1.210",
"OS_windows":{
"pathsmap":[
["P:/", "//mnt/STORAGE/"]
