Mantra frames per task doesn't work
Mikas
Post by Mikas » Thu Oct 31, 2019 11:17 am
I have an issue, I couldn't solve myself. Basically if I set frames per task anything more than 1 mantra still renders 1 frame only. Say I put 2 frames per task. 2 IFD files are being generated correctly, and then mantra task finishes one frame only and marks job as finished.
IFD generation executable:
frame 1-2
hbatch[hbatch]:1000 frames(1,2,2):
Command:
hrender_af -s 1 -e 2 --by 1 -t "_current_" "N:\PRJ\RND\18008_AzureTests\SHOTS\test\LIGHT\pig_oracle_test_open_shader_v012-mantra_render-_current_.1031-131341-596.hip" "/out/PIG"
Working Directory:
Files:
N:\PRJ\RND\18008_AzureTests\SHOTS\test\IMG\RENDERS\LIGHT_CHAR_PIG_V037\LIGHT_CHAR_PIG_acescg_V037_0001.exr
N:\PRJ\RND\18008_AzureTests\SHOTS\test\IMG\RENDERS\LIGHT_CHAR_PIG_V037\LIGHT_CHAR_PIG_acescg_V037_0002.exr
Mantra job seems to take into account only first frame and ignore $F4 variable:
frame 1-2
mantra[mantra]:1000 frames(1,2,2):
Command:
mantra -V a -f N:\PRJ\RND\18008_AzureTests\SHOTS\test\CACHE\IFD\LIGHT_CHAR_PIG_V036\LIGHT_CHAR_PIG_V036_0001.ifd.sc
Working Directory:
And afwatch shows that job as done without errors, though mantra rendered one frame (screenshot):
https://drive.google.com/file/d/16fQ79K ... sp=sharing
Re: Mantra frames per task doesn't work
Post by timurhai » Thu Oct 31, 2019 12:30 pm
As far as i know mantra can`t render several ifds. And mantra command can't process $F4 or %04d or other numeric patterns in ifd file name.
So it can render one frame per command only.
And you should keep it mind generating jobs.
Mikas
Post by Mikas » Thu Oct 31, 2019 12:44 pm
I see. So basically mantra task is limited to one frame per task only then? Is it possible to group them somehow?
Basically what I'm trying to achieve is to launch an instance in the cloud and tell it that I want to render say 10 frames on it and then terminate the instance (node). Is there any way to wrap several mantra frames into one task like this?
Post by timurhai » Thu Oct 31, 2019 1:01 pm
You can run your script, that will run mantra command in cycle to render an ifds sequence.
Mikas
Post by Mikas » Thu Oct 31, 2019 1:29 pm
Thanks for the suggestion, will try that.
