host custom property
tonton
Post by tonton » Fri Mar 16, 2018 2:30 pm
Hi !
i'm trying to add a custom property per host to be able to render only if this property exists (in the end, it's for using blender GPU only on capable machines) but i'm having trouble in finding the good way of doing it...
Is it in the CGRU/afanasy/farm.json file ?
Thank you very much ! :)
Re: host custom property
Post by timurhai » Sun Mar 18, 2018 11:39 am
You are right:
http://cgru.info/afanasy/server#farm_properties
You should create some pattern with a mask that much machines names with "gpu".
Than, on a job you can set "Properties Needed" to "gpu".
CGRU 2.2.3 Ubuntu 14.04LTS (gcc4.8.4)
