afanasy + renderthreads
sdm
Post by sdm »
Is it possible to use this script:
https://github.com/timmwagener/renderthreads
with afanasy render farm ?
last modify date for renderthreads is 2015, but it is work even with 10 nuke version.
Re: afanasy + renderthreads
AfRender just launch commands that were constructed by some submission script and sent to AfServer with a job.
If you can describe your needs within a command line, you can use Afanasy to distribute your commands over farm.
If this is some Nuke Python wrapper, CGRU Nuke submission script already uses its own wrapper to change paths for different Os-es and to render into temporary image file.
If you want to use CGRU submission you should mix 2 wrappers.
If you use own submission script you can already do anything you want.
