How to use Nimby Scheduler
crisosie
Post by crisosie » Fri Sep 07, 2018 12:59 pm
I've been looking for some documentation about Nimby but haven't found anything other than this
http://cgru.info/afanasy/server#farm_nimby_idle_cpu
We are trying to program our computers so that they will start rendering at a certain time (say midnight) and stop rendering at another time (say 7am).
Is there an easy way to do this? How would you do this? Can I have a step to step guide?
Thank you in advacne!!
Re: How to use Nimby Scheduler
Post by timurhai » Wed Sep 19, 2018 11:00 am
Sorry for a delay, i was on vocation.
There is a Nimby Scheduler in a CGRU Keeper http://cgru.info/keeper
CGRU Keeper is a Py(Qt|Side) program that should be launched with a display by a logged in user (CgArtist).
It can turn on and off Nimby at configured time on a logged in workstations.
You can also configure auto Nimby in a farm setup (configuration) file http://cgru.info/afanasy/server#farm_nimby_idle_cpu
For example Nimby will be turned off automatically by afserver when a free (has no afanasy tasks) machine has less than 5% CPU (nimby_idle_cpu=5) for last hour (nimby_busyfree_time=3600)
This way no keeper, display and logged in user needed, you can use this on render nodes and workstations.
rhradec
Post by rhradec » Thu Mar 12, 2020 5:30 pm
There's no setup to turn NIMBY on automatically by the farm setup, right? Is the only way to turn it on by using the keeper?
I'm trying to "auto-on" nimby (and also eject running renders when nimby is turned on) when users start using the machine, so to avoid frustration.
Post by timurhai » Fri Mar 13, 2020 10:52 am
You can setup farm to set/unset nimby depending on cpu/mem/disk/network usage.
And not on time or user login.
