Pathsmap
VisorBNV
Pathsmap
Post by VisorBNV » Fri Jan 27, 2017 4:55 pm
How to proper set pathmaps? I have some questions:
1. What side (server/client/node)?
2. What directions(first from or first to)?
3. OS-style is *nix for windows network paths or native with "\\"?
Please help me to set up this very useful option for mixed environment.
Re: Pathsmap
Post by timurhai » Fri Jan 27, 2017 5:06 pm
There is a good example in docs:
http://cgru.info/afanasy/render#paths_map
and an explanation.
Have you read it?
Re: Pathsmap
Post by timurhai » Fri Jan 27, 2017 5:15 pm
O, i forgot to mention that it is a CLIENT <-> SERVER pairs.
Just added it do docs.
VisorBNV
Re: Pathsmap
Post by VisorBNV » Fri Jan 27, 2017 6:46 pm
Missed this part of the doc, sorry.
Many thanks!
brother john
Re: Pathsmap
Post by brother john » Sun Feb 19, 2017 9:25 pm
OOI, for anyone else interested, here is my working config.json. We work on Windows machines, the CGRU Server is Linux and the blades are Linux:
{"cgru_config":{
"":"copied here by me",
"af_servername":"xxx.xxx.xxx.xxx",
"OS_windows":{
"pathsmap":[
["L:/", "//mnt/l/"],
["M:/", "//mnt/m/"],
["O:/", "//mnt/o/"],
["P:/", "//mnt/p/"],
["U:/", "//mnt/u/"]
"previewcmds":["P:/z_render/cgru-windows/utilities/djv/bin/djv_view.exe \"@ARG@\"","P:/z_render/cgru-windows/start/AFANASY/vrimg2exrFrame.cmd \"@ARG@\"","P:/z_render/cgru-windows/start/AFANASY/vrimg2exrAll.cmd \"@ARG@\""]
VisorBNV
Re: Pathsmap
Post by VisorBNV » Thu Mar 02, 2017 7:47 pm
It works when win-workstation have this part of config and every render-blade are linux machine. Because paths translates on workstation side and comes to render translated. I have linux-renders and some free windows-workstations, that becomes renders for a time. Back translation on windows-render doesn't work...
Re: Pathsmap
Post by timurhai » Fri Mar 03, 2017 9:43 am
We have the same situation at work.
And paths map works fine in both directions.
You should dig this issue deeper.
See render logs for example.
Afrenders on windows has the same config as sibmission scripts?
VisorBNV
Re: Pathsmap
Post by VisorBNV » Fri Mar 03, 2017 10:05 am
One config for keeper and render on windows. CGRU installed on every workstation and blade locally.
Timur, can you show example of proper pathmaps configuration for ours situation?
Re: Pathsmap
Post by timurhai » Fri Mar 03, 2017 10:18 am
On any Windows (render,workstation) config.json in CGRU root folder:
{"cgru_config":{
	"include":["/cg/share/config.json"],
On any Linux (render,workstation) config.json in CGRU root folder:
{"cgru_config":{
	"include":["T:/config.json"]
A part of config.json in that shared location:
"OS_windows":{
		"pathsmap":[
			["P:/",             "/cg/prj1/"],
			["T:/",             "/cg/share/"],
			["c:/cg/",          "/cg/"],
			["c:/temp/",        "/tmp/"]
Re: Pathsmap
Post by timurhai » Fri Mar 03, 2017 10:21 am
Also on in the docs there is a real paths map config too:
( from another studio )
