saving logs next to render frame
dagtm
Post by dagtm » Fri Jan 11, 2019 7:35 am
Is there an easy way to get houdini console output (render logs) and safe it to separate file next to the render output (or any specified location for that matter) ?
Re: saving logs next to render frame
Post by timurhai » Fri Jan 11, 2019 8:45 am
You can customize Python parser class. Even better to use some custom, leaving original unchanged.
https://github.com/CGRU/cgru/blob/maste ... /hbatch.py
You can read/write any files (do anything) during output parsing.
dagtm
Post by dagtm » Fri Jan 11, 2019 11:46 pm
thanks for the answer!
As far as I understand, this parser is just going to give me information provided by afanasy parser method. Can I get original Houdini information that is printed out as well ?
Post by timurhai » Sun Jan 13, 2019 12:12 pm
(May be i did not got you...)
Parser parses original command (child process) output.
If command launches Houdini, parser parses original Houdini (hython) information.
dagtm
Post by dagtm » Wed Jan 16, 2019 4:09 pm
ah, yeah, it's clear!
I got confused by looking at it's methods at first.
