some render close
ahmad
some render close
Post by ahmad » Sat May 25, 2019 4:37 pm
I don't know if this is the right place to post.
I have a problem after updating to Cgru 2.3.1
some render demon die and must be restarted. is there a misconfiguration or something. there is no error record.
Re: some render close
Post by timurhai » Sun May 26, 2019 5:59 pm
You also should see afserver and afrender processes stdout.
ahmad
Post by ahmad » Mon May 27, 2019 6:45 am
from afserver stdo
I don't know what that means
from afrender can't see stdo because afrender cmd close
Post by timurhai » Mon May 27, 2019 10:14 am
To see afrender stdout you can run afrender from cmd.exe, for example.
  • Run cmd.exe.
  • Go to cgru root folder
    cd [CGRU ROOT FODLER]
  • Setup cgru environment
    call setup.cmd
ahmad
Post by ahmad » Tue May 28, 2019 1:34 pm
stdout from AFrender
Post by timurhai » Tue May 28, 2019 2:50 pm
There is a network connection problem periodically on your farm.
Try to increase connection lost time
https://github.com/CGRU/cgru/blob/maste ... .json#L129
For example from 10s to 30s, or even 60s.
PS
If you are using Blender, why not to use Linux on farm?
There are always less network and other problems on Linux.
I never heard about big farms on Windows.
ahmad
Post by ahmad » Wed May 29, 2019 3:14 pm
thank you for help.
later i will try to increase connection lost time.
but for now I'm using a batch script to check every 15 minutes. if afrender still running. and restart if not.
at first we did not have a plan to make a large render farm, only 5 to 10 farms.
but I don't know how suddenly it became very big.
next we do have plans to switch to Linux, maybe after the holidays.
any advice good distro may be?
Post by timurhai » Wed May 29, 2019 5:43 pm
I am using Ubuntu LTS for a long time.
Now it is Ubuntu 18.04.1 LTS.
You can see what i am using in my signature.
Better if everyone will have such signature, to not to specify/ask version and OS every time.
