C4D R20 // not loading RENDER TO FARM
vdobrv
Post by vdobrv » Tue Jun 11, 2019 1:25 pm
C4D R20 starts normally
But in the plugins there is no RENDER TO FARM, but have Export to NUKE
And in the console such a record
File "C:\Users\ren\AppData\Roaming\MAXON\CINEMA 4D R20_4FA5020E\plugins\python\RenderOnFarm.pyp", line 4, in <module>
import cgruutils
ImportError:No module named cgruutils
Loaded Cerebro plugin: True
But at 19 with the same configuration everything works fine
vdobrv
Re: C4D R20 // not loading RENDER TO FARM
Post by vdobrv » Tue Jun 11, 2019 1:26 pm
Windows 7
Afanasy 2.3.1
Post by timurhai » Tue Jun 11, 2019 5:06 pm
It seems that your python does not have cgruutils module in PYTHONPATH.
How you setup CGRU?
How are you running C4D?
How you add cgru/afanasy plugin/script in C4D?
- lot of questions.
You should run soft from CGRU Keeper if do not want to deal with CGRU environment manually.
