New web Gui
New web Gui
Hi All,
We have developed a new web interface for cgru
https://github.com/Arubinu/Draco-CGRU
We welcome your feedback and your new ideas
Best,
Anthony
Best,
Anthony
Re: New web Gui
Great!
Have you tried this config variable?
https://github.com/CGRU/cgru/blob/maste ... t.json#L13
- to not replace original files.
Later better add an ability to afserver to serve several (any number) of web GUIs at the same time.
Sorry, but for a next several months i will be very busy, and will not have enough time for the project to tests/reviews.
I also working with a new feature - render pools. It will take some time too.
Great!
Re: New web Gui
Thank you for the comment.
Indeed, it would be very convenient to be able to change the theme, and looking at the side of "af_http_serve_dir", I understood that it would change the starting point of the web server.
This is not practical since our interface relies on the scripts and files present from the root of CGRU.
I will suggest adding a variable such as "af_http_serve_index", which would replace "AFGENERAL :: HTML_BROWSER" which is always "/afanasy/browser/index.html".
In this case we could stay on the same basis, keep the original web interface, and leave the possibility to change quickly (involving a restart of afserver)!
Thank you for this tool.
Re: New web Gui
Even better, if each user can choose what GUI to use, so one use can use one GUI and other the other at the same time.
And a config setting for afserver what is the default one.
Re: New web Gui
Thanks a lot for this UI. It's so much more convenient than the default one. And the right click menu's are godsend. Very cool!
Mikas
Renderfarm - Ubuntu 20.04 LTS
Clients - mixed Windows and Linux
Afanasy 3.1.1
Afanasy 3.1.1
Re: New web Gui
Hello Draco,
Does it work on the latest version of Afanasy?
I tried, I replaced the folder, but nothing happened, the webgui that comes with afanasy continues to appear.
Bona Jr.
Bona Jr.
Bona Jr.
Afanasy 3.1.1 | Windows 10
Re: New web Gui
You definitely replaced some other folder.
Because afserver can't show original GUI if it does not exist in original location.
Re: New web Gui
I thought it was weird too.
BUT, I found my mistake. The folder that must be replaced is on the server and not on my computer.
Bona Jr.
Re: New web Gui
It works now?
