Dailies creation error
Customize rules.
priel71
Re: Dailies creation error
Post by priel71 »
This is the walk.json file in the .rules folder inside that dpx folder, I'm not sure if it is of any value to you..
 "folders": {
  ".rules": {
   "num_files_total": 1,
   "size_total": 413,
   "space": 4096,
   "num_images": 0,
   "num_folders": 0,
   "num_files": 1,
   "num_folders_total": 0,
   "size": 413
 "files": {},
 "size_total": 6645272989,
 "space": 6645641216,
 "num_images": 178,
 "num_folders": 1,
 "num_files": 178,
 "num_files_total": 179,
 "num_folders_total": 1,
 "size": 6645272576
Is there any files in "/RAJAH/SCENES/sc002/RAJA_002_020/RESULT/DPX/v010" ?
May be there is some permissions problem.
Try to set "sudo chmod -R a+rwx [to that folder]".
What about other locations, have you tried?
Is there some other location, where dailies works fine?
priel71
Post by priel71 »
Yes, there are 178 dpx files in that folder. This is a project which we have used RULES on for about 4 months now, so there's a lot of dailies made etc, all was working perfect until I updated. It's not a permission error, I have full read / right on the system, and RULES work fine otherwise, if I for instance do a "Convert to Sequence / Movie" on the same DPX folder in the RESULTS, the job works fine and is sent to the farm correctly and renders perfect.
Same issue on all projects I tried, not just this RAJA project.. we have 3 other projects going and it's the same thing.
Can you run that command by hand:
rules/bin/walk.sh -m "projects/RAJAH/SCENES/sc002/RAJA_002_020/RESULT/DPX/v010"
Just launch (paste) it in the terminal in the cgru root folder.
priel71
Post by priel71 »
[camper@mary cgru]$ rules/bin/walk.sh -m "projects/RAJAH/SCENES/sc002/RAJA_002_020/RESULT/DPX/v010"
{"walk":{
 "path" :"projects/RAJAH/SCENES/sc002/RAJA_002_020/RESULT/DPX/v010",
 "time_start"   :"Mon May 18 22:34:36 2020",
 "previous"     :" 179 files, 1 folders, 6 645 272 989 bytes",
 "time_finish"  :"Mon May 18 22:34:36 2020",
 "processed"    :" 179 files, 1 folders, 6 645 272 989 bytes",
"walk":{
 "folders": {
  ".rules": {
   "size_total": 413,
   "space": 4096,
   "num_images": 0,
   "num_folders": 0,
   "num_files": 1,
   "size": 413
 "files": {},
 "num_images": 178,
 "num_folders": 1,
 "num_files": 178,
 "size": 6645272576
 "delta"        :"0 files, 0 folders, 0 bytes",
 "time_run"     :"00:00:00.007",
 "status"       :"success"
[camper@mary cgru]$
Hm!
Try to install on Rules server:
sudo apt install exiftool mediainfo
And run walk again.
priel71
Post by priel71 »
Since I'm on centos7, I installed:
exiv2.x86_64 0:0.27.0-2.el7_6
libexif.x86_64 0:0.6.21-6.el7
python-exif.noarch 0:2.1.2-1.el7.nux
exiv2-libs.x86_64 0:0.27.0-2.el7_6
mediainfo.x86_64 0:20.03-1.el7
libmediainfo.x86_64 0:20.03-1.el7
libzen.x86_64 0:0.4.38-1.el7
tinyxml2.x86_64 0:2.1.0-2.20140406git6ee53e7.el7
(Some packages were dependencies)
Unfortunately, no difference... I restarted the httpd daemon as well, but no change.
priel71
Post by priel71 »
Oh sorry, I missed that you asked me to run walk again, here you go:
{"walk":{
 "time_start"   :"Mon May 18 22:59:13 2020",
 "time_finish"  :"Mon May 18 22:59:13 2020",
"walk":{
 "folders": {
  ".rules": {
   "size_total": 413,
   "space": 4096,
   "num_images": 0,
   "num_folders": 0,
   "num_files": 1,
   "size": 413
 "files": {},
 "num_images": 178,
 "num_folders": 1,
 "num_files": 178,
 "size": 6645272576
 "status"       :"success"
priel71
Post by priel71 »
Apologies, missed the exiftool, didn't know it was a perl package.
Here is walk run again:
{"walk":{
 "time_start"   :"Mon May 18 23:01:59 2020",
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = (unset),
        LC_ALL = (unset),
        LANG = "C.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
 "time_finish"  :"Mon May 18 23:01:59 2020",
"walk":{
 "folders": {
  ".rules": {
   "size_total": 413,
   "space": 4096,
   "num_images": 0,
   "num_folders": 0,
   "num_files": 1,
   "size": 413
 "files": {
  "RAJA_002_020_01418109.dpx": {
   "exif": {
    "width": 2880,
    "bitdepth": 16,
    "file": "RAJA_002_020_01418109.dpx",
    "height": 2160
 "exif": {
  "width": 2880,
  "bitdepth": 16,
  "height": 2160
 "num_images": 178,
 "num_folders": 1,
 "num_files": 178,
 "size": 6645272576
 "time_run"     :"00:00:00.095",
 "status"       :"success"
priel71
Post by priel71 »
you are a rockstar Timur, dailies are working again. :D
Thanks so much for your help, I would not have been able to figure this out myself!
Peter.
