Hi threre,
With 3.1.1 on Windows we observe the following problem. User Cannot Skip or Restart entire Block. Clicking just doesn't do anything. This commands works only for Tasks.
But we can click in a small area between Tasks and click Restart/Skip. In this case it will affects all Tasks from all Blocks.
Can you confirm this issue?
Cannot Skip/Restart Block
Re: Cannot Skip/Restart Block
Yes, i just checked it on Windows.
It seems that such block commands working on Linux only.
It is a bug.
I will check it!
It is a bug.
I will check it!
Fixed:
https://github.com/CGRU/cgru/commit/a30 ... 092b99c80a
Will be available in the next release, or you can build the project manually.
