Houdini 19 does not start with cgru 3.2.1
Juan3d
Post by Juan3d »
hi i'm having a problem with houdini 19
It does not start from the afanasy launcher with the cgru 3.2.1 version but 3.2.0 starts fine
maybe something changed in h19
I do not understand well what is happening
win 10
Re: Houdini 19 does not start with cgru 3.2.1
3.2.1 windows release moved on an new MSVC Python and Qt versions:
https://cgru.readthedocs.io/en/latest/c ... tml#v3-2-1
This is a most probably reason of a new error.
For now i do not have MS Windows and Houdini by hand.
You can play with these files:
https://github.com/CGRU/cgru/blob/maste ... python.cmd
https://github.com/CGRU/cgru/blob/maste ... oudini.cmd
May we should change environment initialization.
Try to remove this line first:
https://github.com/CGRU/cgru/blob/maste ... hon.cmd#L9
If keeper will not start after it, restore this line, and place
set QT_QPA_PLATFORM_PLUGIN_PATH=
here:
https://github.com/CGRU/cgru/blob/maste ... ini.cmd#L3
Juan3d
Post by Juan3d »
Removing this line worked great
thanks!
