afrender.service on NFS mount
keyframe
Post by keyframe »
Heya,
Previously running 2.2.3 I was able to deploy afanasy via a centrally installed NFS mount symlinked to /opt/cgru.
Since version 2.3.1 has shifted to systemd, it seems that i'm unable to run the same scam, since the unit file must reside on a filesystem available at PID1.
AFAIK, this is not a dependency/order to service startup issue, but a hard requirement.
Does anyone have any insight?
G
ps: the primary reason for central deployment is having to modify one set of config files, once... rather then having unique files for each machine.
centOS 8.1, cgru 2.3.1
keyframe
Re: afrender.service on NFS mount
Post by keyframe »
For posterity, I was able to hack around this by relocating the service file to a local drive, and repointing the symlink to it... but it's kinda bleh.
A more elegant solution would be awesome.
G
Everything is normal.
You deploy Afanasy in any custom way.
You can write any own init.d/systedm.d service or modify existing.
For example, i am not using a nfs share for binaries.
And we have such /opt/cgru/config.json:
{"cgru_config":{
	"include":["/cg/tank/config.json"],
And /cg/tank is our (nfs) shared tools/scripts/configs location.
CGRU 3.1.0, Ubuntu 18.04 LTS, MS Windows 10 (clients only).
keyframe
Post by keyframe »
Heya Timur,
As you pointed out, everything is normal.
What I didn't know ahead of this process (that I know now) is that service unit files for systemd MUST live on a local file system due to some internal caching/dependency build mechanism.
Basically, if I host the unit files on a remote drives, the system can't see it at boot, and the service fails to start - and it's not simply a matter of waiting for the remote drive to be mounted.
see here: https://github.com/systemd/systemd/issues/8307
G
