Render Pools
Re: Render Pools
Have added the most of the render commands to afcmd, although I would suggest that "reassign pool" be renamed to "unset pool" or "reset pool"
Re: Render Pools
Hmm... It seems that for now WebGUI can set it only for render (not pool).
( as i said, i just implementing it )
CGRU 3.1.1, Ubuntu 20.04 LTS, MS Windows 10 (clients only).
Re: Render Pools
You mean the other way around?
I found where I could change it for the pool, but not for the render
Seems that render is missing the parameter completely
Re: Render Pools
The next six parameters are play no role.
I just forgot to remove them.
I decided class af::Pool and af::Render will inherit af::Farm and all capacity/services/limits parameters will be in af::Farm
https://github.com/CGRU/cgru/blob/maste ... y/affarm.h
( for now only services and disabled services are preset )
But render still has capacity parameter
https://github.com/CGRU/cgru/blob/maste ... der.h#L101
And it plays role the same as before (but now it can't take it from farm.json).
"You mean the other way around?"
- Sorry i did not got you.
Re: Render Pools
So should capacity be stored in a new 'm_max_capacity" similar to pools or keep the old 'm_capacity'?
Anything I can help with or are you already in the process of all these changes?
And should this be moved to github instead?
