Maya Submission Scripts/Plugin Setup
nospitters
Post by nospitters »
hi,
i am trying to setup cgru with maya 2018-2020...to render with redshift.
however i dont get the submission scripts showing in maya.
can somebody give me a hint how to setup the maya submissstion plugins/scripts, so i can submit jobs from inside maya?
(the documentation doesnt help much on this...)
cgru version 3.1.1, windows 10
nospitters
Re: Maya Submission Scripts/Plugin Setup
ok found out in the meanwhile...
something like this if someone wonders:
in maya python script editor:
from afanasy import *
ui = UI().show()
Hm... I see that nobody supporting Maya documentation:
https://cgru.readthedocs.io/en/latest/s ... /maya.html
Very pity ((
But project is open-source and you can write something! ))
If you can't (do not want) to edit rst on github, but really want to help with docs, you can just write something on forum, and i can update
https://github.com/CGRU/cgru/blob/maste ... e/maya.rst
