Run batch file before and after job
tpolson01
Post by tpolson01 »
Is there a way to automatically run a launch command on all render nodes before a render node starts rendering a new job then run another launch command on all render nodes after it finishes rendering the job?
Re: Run batch file before and after job
You can write a command wrapper.
For example some script that will replace "render command", which can contain:
pre_script.sh
"render command"
post_script.sh
tpolson01
Post by tpolson01 »
Thanks. Where would I place this? Or is this a custom render command script?
Yes, this is a custom command script.
You should replace your "render command" by this.
