Branches hosts mask exclude
artem.lavilin
Post by artem.lavilin »
Hello :) ! Can i change hosts_mask_exclude in branch params with json-request protocol?
  'action':
      'type': 'branches',
      'name': '/',
      'params':
          'hosts_mask_exclude' : 'some_mask',
I got
{u'info': {u'text': u'Invalid action.', u'kind': u'error'}}
Re: Branches hosts mask exclude
To see json actions, you can perform something from a GUI and look at WebGUI log, or AfWatch stdout.
Also, here is some examples:
https://github.com/CGRU/cgru/tree/master/examples/json
This is a good example on this topic:
https://github.com/CGRU/cgru/blob/maste ... arams.json
There is no "name" method to specify action node(s), use "ids" array or "mask" regular expression. In you case, you can just change "name" on "mask".
Also any action must have "user_name" and "host_name" fields (for now it is used for logging only, but later it designed for permissions).
artem.lavilin
Nice! It's work, thank you! :)
