Keeper not starting up
Posted: Thu Jul 30, 2020 8:14 am
by Khiladi
Hi Timurhai,
I have been trying to start cgru in windows.
Whenever I run start.cmd in cgru root folder, nothing happens.
No CGRU in system tray.
Thanks!
Re: Keeper not starting up
Posted: Thu Jul 30, 2020 8:15 am
Try to run in the console (cmd.exe).
May be it ouputs some errors.
Posted: Thu Jul 30, 2020 8:32 am
by Khiladi
Hey Thanks for the reply
Did that but it doesn't show any errors. Here is the link to the screen capture.
https://drive.google.com/file/d/1sZoivc ... sp=sharing
Posted: Thu Jul 30, 2020 8:36 am
You can not to send movies, better just copy text here.
You should run start.cmd
start - is command that runs raises new cmd.exe window
Posted: Thu Jul 30, 2020 8:40 am
by Khiladi
Yes, I did that I ran start.cmd, it opens a terminal and then closes it. That's it.
Posted: Thu Jul 30, 2020 8:44 am
by Khiladi
OKay I did that again now this message is coming in terminal
CGRU_VERSION 2.3.1
"Using CGRU Python: C:\cgru.2.3.1.windows\cgru.2.3.1\python"
but still keeper not started
Posted: Thu Jul 30, 2020 8:48 am
1. Can you find keeper (python3 with keeper) process in some process viewer?
- may be you unable to see tray icon, but keeper is running.
2. Try to run "start.cmd f"
Posted: Thu Jul 30, 2020 8:51 am
by Khiladi
I did what you asked and this came
CGRU_VERSION 2.3.1
File "C:\cgru.2.3.1.windows\cgru.2.3.1\utilities\keeper\keeper.py", line 36, in <module>
from Qt import QtWidgets
File "C:\cgru.2.3.1.windows\cgru.2.3.1\lib\python\Qt.py", line 43, in <module>
import shutil
File "C:\cgru.2.3.1.windows\cgru.2.3.1\python\lib\shutil.py", line 10, in <module>
import fnmatch
File "C:\cgru.2.3.1.windows\cgru.2.3.1\python\lib\fnmatch.py", line 14, in <module>
import re
File "C:\cgru.2.3.1.windows\cgru.2.3.1\python\lib\re.py", line 142, in <module>
class RegexFlag(enum.IntFlag):
AttributeError: module 'enum' has no attribute 'IntFlag'
Posted: Thu Jul 30, 2020 9:02 am
It seems that Python that came with CGRU does not work.
It definitely works on other machines.
Have you changed it somehow?
Have you some special python environment on than machine? (May be some PYTHON_PATH, PYTHON_HOME variables?)
Try to unpack a fresh CGRU archive on a fresh Windows machine.
Try to reset some environment first:
SET PATH=
SET PYTHON_HOME=
SET PYTHON_PATH=
start.cmd f
Posted: Thu Jul 30, 2020 9:06 am
by Khiladi
Will do it Thanks!!!
