Wrong client IP address
Mikas
Re: Wrong client IP address
Post by Mikas »
I was using "wolwake @IP@" in my config, now it's not passing correct IP anymore
Mikas
Renderfarm - Ubuntu 20.04 LTS
Afanasy 3.1.1
Nothing changed on this theme on latest updated, and for a very long time.
Your network setup makes server to thing that all renders are from the same IP.
(i bet that it is an IP of some router that renders connects to server from)
As far as i understand, you have some custom tool to wake renders.
And it gets a render IP from server. How?
You also can get full info with all IPs, how?
If it is a render item double click from afwath, you can launch afwatch from console, and see how it gets full info.
you can wake render using mac address not ip - use broadcast message.
Mikas
Post by Mikas »
Thanks Timurhai.
All the rendernodes are on the cloud, probably cloud provider changed something and as coincidence I saw it after upgrade. Sorry about that.
To answer your questions:
1. I use custom tool that wakes nodes based on IP addresses, as I don't have their physical addresses
2. I use config.json option:
"af_render_cmd_wolwake":"wolwake @IP@"
- this is where I send nodes IP
3. I get full info from Afwatcher right click on the node and pressing Show Info
I have one node running on the same node as Afserver, which wakes render nodes when needed
Mikas
Afanasy 3.1.1
Mikas
Post by Mikas »
Basically if I send that command
wolwake some_IP_address
manually - it still works. So my question is - how can I get that IP from the network card rather then from socket? Is it possible?
Mikas
Afanasy 3.1.1
Yes. You can launch afwatch from a console, and see how it gets full info.
In a console mode, afwatch prints in stdout messages that it sends to server.
This is the way to learn Afanasy JSON protocol.
Mikas
Post by Mikas »
Cool!
Thanks a lot Timurhai, your help much appreciated!
Mikas
Afanasy 3.1.1
Mikas
Post by Mikas »
I ran afwatch from command prompt, but it doesn't provide any output there:
Screenshot 2021-02-19 165320.png (156.47 KiB) Viewed 5701 times
Any options I need to turn on while running it?
Mikas
Afanasy 3.1.1
Sorry, it is only for Linux.
Windows version drops console.
Also you can look at web gui network logs. (left-bottom button with an arrow)
Mikas
Post by Mikas »
Thanks Timur!
Mikas
Afanasy 3.1.1
