blender 2.8 beta
ari_pitchi
Re: blender 2.8 beta
Post by ari_pitchi »
shq wrote: Fri Jun 28, 2019 1:05 pm thanks for the swift reply; it seems that my colleague managed to modify original code. we will provide the modified addon after few tests next week
Hi, is there any possibility you can upload and link to the modified addon your colleague changed or perhaps privately send me the addon for testing purposes? we are working on using cgru in our farm to render 2.8 files and i could not get the addon to properly load on version 2.8 (as i have only limited experience with python coding and got stuck on some issues..)
Thanks!
shq
Post by shq »
hi. here is the current version we have. it still causes some error messages and works only on one of our machines ... colleague who rewrote it is on his vacation right now, so I cant tell whats wrong. Maybe you will have more luck and find solution. Cheers.
https://drive.google.com/file/d/1r4PxI_ ... sp=sharing
shq
Post by shq »
final version - works now without error messages. cheers
https://drive.google.com/file/d/1TMOsGH ... sp=sharing
Great!
How about to use GitHub?
https://github.com/CGRU/cgru
It is much more comfortable to track code changes there.
But if you can`t(do not want) - i will merge it. Anyway, thank you for developing!
shq
Post by shq »
hi,
sorry im no developer - im just sharing. Do whatever you want with the code. Update is written by my colleague Radovan Jaron @ Xlab.cz
Regards,
Petr
shq
Post by shq »
..and also many thanks for your work on whole system! I hope we will use it in production..
ITdreamer
Post by ITdreamer »
On some scenes we have this kind of error. It seems that the problem is in cgru addon for blender.
Here is screenshot
https://ibb.co/85hv2SX
I can't find the regularity of this error for now.
It seems to me that there is some problem with collections in this addon.
SteffenD
Post by SteffenD »
This seems to be the same or a similar problem that I already reported some time ago here viewtopic.php?p=4562#p4562
The trick is to put a renderable object (not an empty e.g. but rather a cube with all faces deleted in edit mode) in the root of the scene collection.
ITdreamer
Post by ITdreamer »
Well, maybe it is a solution, but it is very difficult on large scenes.
It needs more complex fix.
