machines fails to come back online after reboot
keyframe
Post by keyframe »
... from the first world problems category ...
I've noticed several of the newer machines reboot faster then they become deregistered from afserver.
When they come back online and attempt to register, they get rejected because afserver hasn't realized that they've rebooted.
There are several timing related fields that could help with this in config_default.json, but i'm not clear which I should be tweaking.
Any tips?
G
Rocky Linux 8.5, cgru 3.2.1
Re: machines fails to come back online after reboot
This is:
https://github.com/CGRU/cgru/blob/maste ... .json#L129
In our studio we have:
"af_render_zombietime":16,
"af_render_connection_lost_time":20,
"af_monitor_zombietime":16,
"af_watch_connection_lost_time":20,
I should set some lesser default value for everyone in feature releases.
You should not change cgru/afanasy/config_default.json file. Changing this file will make version change more difficult, as this file is changing from release to release.
You should create cgru/config.json and put there only fields that you adjusted.
keyframe
Post by keyframe »
Thanks Timur,
Much appreciated. Do any files with the .json extension get loaded? or is it specific to config.json and farm.json?
G
Fixed it on GitHub:
https://github.com/CGRU/cgru/commit/54b ... 1b96d688b5
Will be by default in the next releases.
