Dailies creation error
Customize rules.
Re: Dailies creation error
Do you have "exiftool" command on server?
Great!
I should remember this issue.
Or dailies should work w/o exiftool, or there should be written somewhere and some error should be printed.
priel71
Post by priel71 »
I will help you write this up in your docs plus a few other things I can think about from my years using RULES, didn't you have a github for the doc sources?
CGRU documentation will be (and should be) totally rewritten using sphinx and rst (for now it is just started).
Sources:
https://github.com/CGRU/cgru/tree/master/docs
Result:
https://cgru.readthedocs.io/en/latest/i ... index.html
priel71
Post by priel71 »
So shall I update the RULES dox or should I wait until you have the new documentation system done?
priel71
Post by priel71 »
Ah, spoke too soon. I see it's already up and running. Ok, will offload some of my limited knowledge of RULES there and submit once I got something. Thanks again Timur.
