AfWatch - Output file missing
Baden
Post by Baden »
Hi :)
after I tried a firewall software in some machines, the txt log file can't get it by afwatch. :cry:
The error:
ERROR: Can't get file:
c:/temp/afanasy\jobs\0\355.cache-18\tasks\0.0\output\1.txt
No such file or directory
Exists a rules or a specifics setting for fix that problem? :?:
3D Animator
Re: AfWatch - Output file missing
Can you show (paste) task log here.
Baden
Post by Baden »
in Executable there are the correct informations;
in Output:
Log:
Thu 25 Feb 15:03.46 : SESSION #1: Starting on "mypc"
Thu 25 Feb 15:22.52 : Finished success.
Error Hosts:
Task has no error hosts.
3D Animator
Does that file exists?
If not, may be server can't write there, may be some permissions error.
Try to see server logs, may be some error it there.
Baden
Post by Baden »
I suppouse that is the message:
Fri 26 Feb 14:13.41: ERROR Type is not NULL.
3D Animator
Where this message appears? And after what?
