Central settings for CGRU Keeper
vfxgeek
Post by vfxgeek »
I'm trying to set up a multiuser environment, and apparently for each new user that logs in to a system CGRU settings are set to default.
Is there a way to have a central configuration that would be used by all system users?
Lukas
Re: Central settings for CGRU Keeper
Yes, better to hava a central configuration.
We keep the CGRU installation locally.
In the CGRU root folder we have a "config.json" file, that contains just an include directive to read another one:
{"cgru_config":{
	"include":["/cg/tank/config.json"],
"/cg/tank/config.json" - is a network location, it is the same file for everyone.
vfxgeek
Post by vfxgeek »
Perfect. Thanks very much for your help.
Lukas
