Windows installation connection refused
Ronny_D
Post by Ronny_D »
first of all thank you for the program.
For some reason it is not able to make connection.
I keep getting this message: Could not open socket.
[Winerror 10061] Connection refused. No connection could be made because the target machine actively refused.
Build is cgru.2.2.3.windows
Im on windows 10 for the master and client.
The slaves are windows server 2012 r2 and windows 7
between there is a nas and switch and I'm able to remotecontrol the slaves.
I do not know how to solve this issue myself?? I tried turning of firewalls and stuff like that..
Kind regards
Ronny
Re: Windows installation connection refused
May be you missed some firewall ?
Ronny_D
Post by Ronny_D »
Yes, I turned them all off, also the adblocker.
Try to perform some other server <- client connection (may be some other application).
Try to connect server via Afanasy WebGUI.
Ronny_D
Post by Ronny_D »
I openend the Afanasy web GUI this morining, I did something and it doens't seem to work anymore I don't know what poort it should be.
Recown
Post by Recown »
Ronny_D wrote: Tue Jun 26, 2018 3:37 pm Hi,
Kind regards
Ronny
Just right now i have the same issue. It's not an afanasy or afrender, or anything else problem. Socket connection runs ok if i launch test python script from Desktop (for example) . But it's totaly not working inside Nuke (for example). This issue persist only on single PC. Just some moth***g windows jokes. Firewall and antivirus are totaly shutdowned.
Recown
Post by Recown »
Found the problem. It was some kind of 3rd party firewall. Correct setup and problem gone!
