Single host simulation don't show percent of progress in task GUI
ingwar
Post by ingwar »
When I send Houdini simulation on farm as a single host (Alfred style progress ticked on) I see % in output but not in task GUI .
What I need to fix to make it visible as increasing progress bar?
Thanks.
Re: Single host simulation don't show percent of progress in task GUI
Can you provide more task info (service, parser, command).
And a full task output.
ingwar
Post by ingwar »
Hi! This is from my simulation log
EXECUTABLE
frame 1
hbatch[hbatch]:2400 frames(1,1,1):
Command:
hython "/projects/episodes/abc/scenes/lighting/.abc_lighting_v006.~abcrender~.07.19.13.14.Y5mEnq.hip" "/abc/tools/houdini/configs/houdini16.0/scripts/abc_hrender.py" --ignore_inputs --create_folders --start=50 --end=205 --by=1 --take=_current_ --rop=/obj/geometry/rocks/ropnet/smoke
Working Directory:
/abc/projects/episodes/abc/data/cache/generic/rocks
Files:
/abc/projects/episodes/abc/data/cache/smoke_02_0000.0130.bgeo.sc
OUTPUT
grep: /home/renderer/houdini16.0/hcommon.pref: No such file or directory
/abc/projects/.settings/houdini_fix: line 7: /home/renderer/houdini16.0/hcommon.pref: No such file or directory
sed: can't read /home/renderer/houdini16.0/hcommon.pref: No such file or directory
Warning! Unexpected error while opening /home/renderer/.cgru/config.json.
Error: [Errno 2] No such file or directory: '/home/renderer/.cgru/config.json'
TAKE= Main
Creating folder /abc/.data/episodes/abc/data/cache/0290/smoke_02_0000 ... Ok
ALF_PROGRESS 0%
ALF_PROGRESS 1%
ALF_PROGRESS 1%
ETC to 100%
ALF_PROGRESS 100%
About Afanasy in general
Compilation date = 'Dec 7 2016 11:18:26'
CGRU version = ''
Afanasy build revision = '3257e36bd86aa0c5982b9c3299916c438916f0cf'
Python version = '2.7.9'
GCC version = '4.9.2'
Sorry I'm not sure about parser and service info where I can find them
hbatch[hbatch] - means that service is "hbatch" and parser is "hbatch".
It seems that you are not using CGRU submission script (not "afanasy" ROP node).
You have a custom submission script, and entirely custom CGRU setup, as CGRU_VERSION environment variable is empty.
Afanasy "hbatch" parser does not look for ALF_PROGRESS.
You can use afanasy "mantra" parser, it does.
Generally if you are generating own commands, you should use own services and parsers.
You should not expect that a CGRU provided parser will work with a custom command correctly.
pps
Also Afanasy common workflow is broken in you command.
Afanasy tasks has frames attributes (start, end, and so number of frames).
You have "--start=50 --end=205" but frame numbers are "frames(1,1,1)".
Frames are used to calculate dependencies.
With a correct frame settings and native CGRU submission scripts (ROP nodes) you can:
Start a 100 frames simulation, and render 100 tasks within the same job.
Frame 1 will start to render just after it will be simulated.
This way simulation render will not wait the entire simulation finished.
ppps :)
Some studios uses Afanasy "engine" only, almost all scripts are in-house, but they are better than CGRU native (at least for their needs).
You are using custom scripts that have less functionality that CGRU native does.
