Afanasy on Ubuntu 20.04
romanvolodin
Post by romanvolodin » Fri May 15, 2020 5:00 pm
I've found out that render user group exists in Ubuntu 20.04 by default. So Afanasy can't create user render on installation.
Is there a way to fix this situation?
May be some workaround for Afanasy installation or may be I just can delete this user group? (No idea what this group is for.)
Any info would be helpful.
Re: Afanasy on Ubuntu 20.04
Post by timurhai » Mon May 18, 2020 11:59 am
Try to type this command:
id render
What is the output?
romanvolodin
Post by romanvolodin » Mon May 18, 2020 12:45 pm
On fresh Ubuntu 20.04 installation (I'm using Virtualbox):
$ id render
id: ‘render’: no such user
$ grep render /etc/group
render:x:109:
I've run the following command:
$ sudo delgroup --system --only-if-empty render
Removing group `render' ...
Done.
Quote from delgroup man:
--system
Only delete if user/group is a system user/group. This avoids
accidentally deleting non-system users/groups. Additionally, if
the user does not exist, no error value is returned. This option
is mainly for use in Debian package maintainer scripts.
--only-if-empty
Only remove if no members are left.
And then Afanasy was successfully installed.
After Afanasy install:
$ id render
uid=1001(render) gid=1001(render) groups=1001(render)
render:x:1001:
Post by timurhai » Mon May 18, 2020 2:40 pm
Just installed a fresh 20.04 on a virtual box too.
Hm, new group "render" appeared in 20.04 just after installation.
And i checked that there are no users in it.
So i do not know why it is needed. Most probably that it is not.
It is not breaks Afanasy installation, but it can't create a "render" user during installation.
So systemd scripts can launch afserver and afrender under render user that does not exist.
After installation, i just created "render" user by
sudo useradd render -g render -m
to put it into existing group.
And after reboot, afserver and afrender was started by systemd.
I think i should check "render" group in the installation scripts, and use existing if it exists.
Post by timurhai » Mon May 18, 2020 4:33 pm
This fixes the issue: (i checked on 20.04)
https://github.com/CGRU/cgru/commit/3bb ... d325800c57
