Greetings.
I used to use Afanasy with Houdini, and did not face a similar problem.
When trying to send via the "Arnold to Afanasy" script(CGRU menu), I get the following error in:
# Error: ValueError: file C:\ProgramData\AFANASY\plugins\maya\afanasy\meArnoldRender.py line 248: No object matches name: defaultArnoldRenderOptions.shader_searchpath #
Arnold renderer is active, the defaultArnoldRenderOptions node is created. Tell me what I'm doing wrong.
Thank you
