After installation not start
Posted: Tue Aug 03, 2021 12:42 pm
Ubuntu 20.04.2
Afanasy 2.3.1
After installation, it gives an error
Does not start automatically
Manually starts
Says he can't find the user RENDER
Although he is
What to do?
Ubuntu 20.04.2
Afanasy 2.3.1
Manually starts
Although he is
What to do?
Installing AFANASY dependences:
Reading package lists... Done
[color=#00BFFF]Building [/color]dependency tree
Reading state [color=#00BFFF]information[/color]... Done
libpq5 is already the newest version (12.7-0ubuntu0.20.04.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Installing cgru-common.2.3.1_ubuntu18.04_amd64.deb
Selecting previously unselected package cgru-common.
(Reading database ... 83537 files and directories currently installed.)
Preparing to unpack cgru-common.2.3.1_ubuntu18.04_amd64.deb ...
Unpacking cgru-common (2.3.1) ...
Setting up cgru-common (2.3.1) ...
CGRU-common post install:
Installing afanasy-common.2.3.1_ubuntu18.04_amd64.deb
Selecting previously unselected package afanasy-common.
(Reading database ... 84483 files and directories currently installed.)
Preparing to unpack afanasy-common.2.3.1_ubuntu18.04_amd64.deb ...
Unpacking afanasy-common (2.3.1) ...
Setting up afanasy-common (2.3.1) ...
Installing afanasy-server.2.3.1_ubuntu18.04_amd64.deb
Selecting previously unselected package afanasy-server.
(Reading database ... 84487 files and directories currently installed.)
Preparing to unpack afanasy-server.2.3.1_ubuntu18.04_amd64.deb ...
Afanasy server PRE INSTALL
Failed to stop afserver.service: Unit afserver.service not loaded.
Failed to disable unit: Unit file afserver.service does not exist.
Unpacking afanasy-server (2.3.1) ...
Setting up afanasy-server (2.3.1) ...
Afanasy server POST INSTALL
id: ‘render’: no such user
useradd: group render exists - if you want to add this user to that group, use -g.
Created symlink /etc/systemd/system/remote-fs.target.wants/afserver.service → /opt/cgru/afanasy/systemd/afserver.service.
Created symlink /etc/systemd/system/afserver.service → /opt/cgru/afanasy/systemd/afserver.service.
afanasy@afanasy:/opt$ sudo adduser render
[sudo] password for afanasy:
adduser: The group `render' already exists.
