Is it possible for the file generated by the pdg scheduler to be owned by the same account that submitted the job instead of 'render'?
PDG scheduler file ownership
Rocky Linux 8.5, cgru 3.2.1
Re: PDG scheduler file ownership
I was able to make that change by modifying a few lines of afanasyscheduler.py.
I'm making use of linux's ability to switch to a different UID/GID and a few security exceptions via sudo - i'm not sure whether this is something that's possible on other platforms.
In case this is useful to anyone else:
[gene@tws12 types]$ diff afanasyscheduler.py afanasyscheduler.bak
175,176c175
< cmd = 'su -m {} -c "umask 022 && {}"'.format(cgruconfig.VARS['USERNAME'], self.expandCommandTokens(work_item.command, work_item))
< task.setCommand(cmd)
> task.setCommand(self.expandCommandTokens(work_item.command, work_item))
467,469d465
< # impersonate someone useful
< cmd = 'su -m {} -c "umask 022 && {}"'.format(cgruconfig.VARS['USERNAME'],cmd)
I think that user switching is a very "in-house depended" issue.
It should be implemented by admins/TDs/RNDs in place.
Also user, that service is running by, should have enough permissions for it.
Just may be Afanasy "out-of-the-box" submission plugins should have some ways for command customizing.
- this i can discuss/implement
As you say - It might be useful for some users to have access to some prologue/epilogue code snippets of some sorts...
If one wanted to update an asset management tool for example... or clean up a cache folder...
We're running custom submit scripts that's very opinionated about how we work, but I reckon someone can benefit from it.
